HELP! Severe undervolting & other problems. Thanks.
L33T
A few days ago this problem developed after OC'g a P4 3.0C and raising the voltage from stock to just under 1.6V (which is by all means, well in the safe range).
After using Prime95 for a bit, the computer shut down with no warning. Now, the following symptoms occur:
1 - The computer doesn't boot up all the time.
a.) Sometimes there will be no post, even at stock.
b.) Sometimes there will be a msg "CPU Unworkable or changed...blah"; pressing F1 will sometimes allow entry into WinXP; sometimes, not.
c.) Sometimes there will be beeping, as in: beeeeeeeeep (pause) beeeeeeeep (pause), etc., and no post
2 - BIOS doesn't save. No post after BIOS restart.
When saving the BIOS to any setting, the computer restarts as normal, but the computer doesn't post aftwards.
3 - Severe Undervolting in VCORE when running F@H:
Under load: 1.24V - 1.36V range
Idle, in WinXP: 1.50V, steady; occasionally drops to 1.47, but rarely.
What do I do? Did I bust the PSU?
It's a 480W, Antec TrueBlue PSU, used for about 1/2 a year.
Current stuff attached:
- CPU
- R9700pro
- Kingston RAM, 512mb
- DVDRW
- CDRW
- HDD1, 40GB
- HDD2, 120GB
- CCFL's, x2, connected to the same molex, but with different ballasts.
- Koolance EXOS, also drawing power from PSU.
Please help; thanks in advance.
Would that be necessary though? It has been running stable for the longest time with this current BIOS.
