I have:
Procurve 1810-24G
Procurve 2520-8-PoE
Router (with Internet Connection) is plugged into port 24 of the 1810.
My asterisk server is plugged into Port 1 of the 1810.
The 2520 is plugged into Port 2 of the 1810, and all of the VoIP phones are plugged into the 2520.
Rest of the office computers are plugged into the remaining ports on the 1810.
Questions:
After setting up the subnet and assigning an ip to the 1810, everything else just worked out of the box. I would imagine that I should segment and prioritize the network so that the VOIP traffic is isolated and is higher priority from everything else.
I tried playing around a bit, but the phones lost connectivity, so I just defaulted everything back for now.
What would the suggestions be for setting up the VLANS properly to do this?
I would also need one of the office PC's (say the one plugged into port 13 of the 1810) to be able to access the asterisk server.
Also, would it be more optimal to have the asterisk server on the PoE switch or the main switch?
Procurve 1810-24G
Procurve 2520-8-PoE
Questions:
