Hi guys,
I just wanted to get some clarification on how / if I can do this. I currently have two computers, both running windows xp. One of the computers is my personal fileserver that I just built, with a ton of HDs. It has an onboard gbit ethernet port. It's using this board:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131014
( ASUS M2NPV-VM Socket AM2 NVIDIA GeForce 6150 Micro ATX AMD Motherboard )
The other computer has a gbit pci NIC card and an onboard gbit ethernet port. The mobo is a Asus P4P800-E Deluxe. The pci nic is connected to my router, for internet access. Right now the fileserver is also connected to the router, but my router is only 100mbit, so I want to directly connect my two computers using a crossover cable.
How do I go about doing this? From what I understand, all I need to do is connect them with a crossover cable, and then assign an ip address to each computer. However, when I tried this, I still didn't seem to be getting gbit speeds. I didn't have a chance to benchmark it, but windows xp was reporting connected at 100mbit on both computers. Is there an advanced option to enable gbit? Or is it possible that windows is reporting an incorrect speed? Do the computers need to be off when I plug the cable in?
Any suggestions on how to test this out / properly set it up are welcome. When I get home from work I'll try it again.
Thanks in advance,
Kevin
Thanks in advance,
Kevin
