lord_emperor
- Feb 1, 2003
I got a free scanner (w00t) but it's SCSI
It's got a 25-pin connector that looks like a printer port (see picture, the one with the red arrow) which goes to the SCSI card I assume.
The other end you see there attaches to the scanner, or it can use a cable that is the same on both ends.
I'm trying to ebay a SCSI card with the external 25-pin connector, but I don't know what the kind I want would be called.
Can anyone identify what SCSI standard that is? Or what is likely to work.
![scsicable.jpg](http://www.lantechgaming.ca/random/scsicable.jpg)
![scsiscanner.jpg](http://www.lantechgaming.ca/random/scsiscanner.jpg)
