I'm working on sleeving my cpu and I want to do the big ATX cable. Most tutorials I've seen say to do this with thin staples but its still sorta vague. Do the staples go in the middle of the metal pin? Or do they go on the outside and sqeeze between the metal pin and then plastic. Also do they go on the sides, or the front and back of the pin? I tried putting the staples on the outside of the metal pin and on the sides but its too thick to fit them in, if one side is in the other wont fit. These staples are very small too, any ideas? Thanks a million
