1Wolf
- Jul 10, 2007
Just have some Vista x64 disk space allocation/partition questions and was hoping for a little help or advice.
I've got a Windows Vista x64 machine. One of the HD's is a 150 Gig drive with two partitions, C & D.
C is the OS partition and D is the "Programs" partition:
I'm starting to run pretty low on space on my OS partition (C). I've cleaned up most everything I could. I do have a decent amount of unused space yet on my (D) partition.
Is it possible, and safe, to take some drive space from my (D) partition and re-allocate that to my (C) partition so that the OS can have some more space?
Under "Disk Management" in windows, I see that I can right-click on the (D) partition and choose "Shrink volume"...however I'm afraid that it could cause data loss, or maybe reduced disk performance.
I've never 're-allocated' space on a partition before so I'm not sure if its possible, exactly how to perform this safely, and if its possible to do safely without data loss or performance problems.
Thanks in advance!
Thanks in advance!
