Help!!! Random Reboots
Patrick1
When i am overlcocking my computer will sometimes randomly reboot
I have OCZ EL GOLD 3.2V at DDR456 and a venice 3000+ 1.65V running at 2556MH.
I have an ok power supply on the lower end of averadge.
I my temps are nice and good where they should be.
Please help guys this is getting anoyying.
I would start with these 2 things. Lower clock speeds, and try a different psu.
U think its a PSU problem?
Oh and i have a dfi lan party ultra-d and my power supply is 20 pin and i have 18amps on the 12V rail. Is this the problem?
Thanks in advance for any help
I don't know this for a fact, but I have read several times that the dfi board absolutely hates the 20 pin psu....must have a 24 pin psu. I can't verify this, as I went for the asus sli-dlx, because I didn't want to replace my 6 week old psu....but i kinda wish i woulda :rolleyes: Maybe next month.
Have you tried some stability tests. Run memtest for a while, run prime95, find out if you get some errors.
Otherwise what is your whole systme specs including hd's, number of fans, everything.
Ok i can run memory test and prime95 for as long as i could posibly want. Its rock hard stable. Although i just randomly have this problem.
AMD64 Venice 3000+ 2.556 1.65V
1G of OCZ GOLD DD400 running at DDR465 3.2V
1 Gigiabyte X800XL
1 DVD Burner
1 250GB hard drive
Dfi Lan party ultra-d
2 120mm case fans
1 92mm case fan
Thermaltake silent boost cpu cooler with 80mm fan
1 Blue Coldcathode
1 Thermaltake Thermaltake 430W Powersupply 18 amps on 12V rail.
Now that you have eliminated the memory I tend to agree with SpoogeMonkey, if you go to DFI-street.com (thinks thats close) you will see right off that the DFI support people wont even want to talk to you till you get a 24pin supply with dual 12V rails capable of at least 28 amps (think thats about right) on the 2 rails combined.
Patrick1 said:
So....... Its safe to conform that this is the work of crappy PSU?
Not that it's crappy...just not the right tool for the job. So far, my asus board is running great w/20 pin psu. I still want to get a new psu and the dfi board tho.
most definatley. that PSU is awesome man, dont pass up on the rebates that they have for it right now. and theres also a 10$ off coupon in the hotdeals sections from neweggwebmaster. its ALMOST as good as the frys Neopower fiasco that we had about 4 months ago.
