Help please
hutchwell
Ok, I was helping a friend of mine put his new computer together today, which is made of...
an Antec SLK1650B case, with 350 watt psu,
a Foxconn nf4uk8aa motherboard,
2x1gb ADATA ddr400 ram,
an EVGA 7950gt ko,
an AMD Athlon 64 4000+,
a Lite-On DVD burner,
and a WD 160gb hd.
We didn't have any problems putting it together, but when we tried to fire it up we got nothing. After testing the psu with a paperclip, we found out it was good. We plugged it back up and this time the computer ran.
However, the monitor (and by this time everything was hooked/plugged up) didn't register a signal. After fiddling with it for hours, trying it on my monitor, trying the video card in my computer, and trying my computer on his monitor, we've ruled out the video card or his monitor being bad.
As far as we can tell everything is hooked up correctly inside.
The only thing left I thought it could be was that his psu might not be pushing enough juice, but I figured I'd come here and ask first before he runs out and gets another. All he wants to do is play BF2, but he's been thwarted.
Anybody got any ideas?
edit: also, first post. Hi!
I'm pretty certain that's not enough power to run the system, try it without the graphics card and see if you can get the fans, harddrive and optical drive to switch on and spin up.
Oh and just to check the obvious, you have plugged the PCI-e cable into the graphics card haven't you?
I'll assume that the psu came with the case, correct? And if that's true, get a new one. Regardless of rather that's the culprit or not, your friend is not going to want to rely on a cheap ass 350w psu to push all of his new gear.
Here are a few other ideas. Remove everything from the case, and start with the mobo on a piece of cardboard or wood, cpu/hsf, one stick of ram, and the psu, and see if it will post. If it does, keep adding parts until you find the problem, and if you are able to get it running outside of the case, then a short would likely be the problem.
Yeah, the card is plugged up, and yeah, the psu came with the case. Even with everything plugged up we've gotten it to turn on, but the monitor gets no signal. The monitor and video card both work on my computer.
He's gonna go get a new psu today (if he can find a place around here that's open, anyway).
We'll try working our way up and see how that goes.
update!
We got a 500w psu for the computer. After we hooked it up and turned it on, we still get no signal and on top of it the dvd-rom won't open.
I'm extremely confused. I guess later we'll try hooking everything up one piece at a time.
if the thing never POSTed, re-seat the CPU. if that doesnt work, try it with only one stick of ram. if that doesnt work, try the other stick. if that doesnt work, try other dimm slots. make sure you're doing all of this outside of the case, like digital_exhaust recommended.
update #2!
Figured out what the first problem was. The manual had the power connection points (I guess I'd call them that) labeled wrong.
Now the damn thing won't install Windows. At least it's running though.
Thanks for your help, peoples.
