Here is what I plan to build in a few weeks
Antec P-180 case
Antec TruePower2-550
Asus A8N-SLI-Premium
AMD X2 3800
HSF Ninja or SI-120
1 ATI X800Pro
2 gigs of memory
2 each SATA HDs
DVD Burner
I plan to overclock this and I also want a quiet machine (cake and eat it too!)
Here are my questions:
1) Will a Scythe Ninja be better or will the SI-120 be better? (using the Antec P180 case)
2) Which 120 mm fan should I use?
Here are my thoughts: If I use the Ninja, I could use a quieter, slower-RPM, fan because it would be next to the case exhaust fan. If I use the SI-120, it would tend to cool the rest of the motherboard, memory, etc.
Antec P-180 case
AMD X2 3800
HSF Ninja or SI-120
1 ATI X800Pro
2 gigs of memory
2 each SATA HDs
DVD Burner
