Hi everyone,
I'm very new to the OC world, and just recently pushed my 3.2EE to 3.6 with a Zalman, but now I'm thinking of moving to phase change in the next couple of months.
I've researched this a bit and I see several makers.
VapoChill
Prometia
Cascade
Jintuu(sp) unit
Not sure if the following are phase change units:
Peltier
Tec
one other but it escapes my memory. From what I read people were using these to chill the water in a water system, so not sure the applicability here.
I don't want to go water cuz it just seems a half arsed step between air and phase change to me.
So what are my options, what am I missing? I've noticed the vapochills are semi reasonable and made here, where the prometia seems to be purely overseas. Also the vapochills seem to be cheaper at about 900 bucks.
Also I have a 6800U that I'd like to take to a more extreme OC (420/1150 atm) is there a unit that can cool both? I guess how do the adapters work can I upgrade them as I upgrade systems.. IE when I move to the 2007 45nm technology or to SLI etc...? Or are these things limited to one GPU or CPU only?
Also how hard is it to build one yourself? I know how to solder copper pipes and wire things up, I wired my last house and all, so not being an AC person I'm curious how hard it would be.
Thanks for any help you can provide.
P.S. we really need a Stickied FAQ that explains some of the Q's I have above in this section!
VapoChill
Prometia
Cascade
Jintuu(sp) unit
Peltier
Tec
