HELP!!!!!!!!!!! need SN41G2V2B info
ubern00b15
i just ordered a SN41G2V2B
how well do they overclock?
whats the highest multiplier it takes?
FSB?
Voltage for CPU?
i have a mobile 2400+ that is useless unless it is overclocked
the multiplier goes up to 20 i think.. the vcore goes up to 2v.. don't touch the vdimm.. it will kill the mobo..
i can get 2.5ghz out of my 2200+ 35 watt with the stock fan and some arctic silver 5
i got the fsb up to 220, but it wouldn't boot into windows.. probably my ram..
they overclock very well..
but isn't this something you should have checked into before you bought it??
do you have a 35 or 45 watt 2400+ ??
you can probably get 2.4 ghz no matter what...
