[email protected]
- Jul 16, 2003
This probably should go in the RAM section, but as it relates to my overclocking situation, I thought I'd ask here first.
I have my computer running stable at 3.2GHz (I should change my sig). I ran Prime95 for about 20 hours and got no errors. Ram is at 1:1. When I ran Sandra, it told me my memory bandwidth was 5527MB and 5592MB. Now, I don't know exactly what that means, but I'm assuming it means my memory bandwidth is about 5.5GB/s ... right?
So I went into BIOS to play around with the RAM timings to see what I could see. Well, I read all the tutorials I could find, and I am still a little unsure what is what in the BIOS. Here is what it looks like in there now:
CAS# LATENCY ....................... 2.5 CLOCKS
RAS# PRECHARGE .................. 4 CLOCKS
RAS# TO CAS# ......................... 4 CLOCKS
PRECHARGE DELAY ................ 8 CLOCKS
BURST DELAY .......................... 4 CLOCKS
DRAM IDLE TIMER .................... AUTO
DRAM REFRESH RATE ............. 15.6
ICH DELAYED TRANSACTION .... ENABLED
MPS REVISION .......................... 1.1
Ok, now I admit, I have no clue what to change here. I would GUESS that lowering the top numbers is the key. If any of you wouldn't mind, could you try to explain this to me in 'idiot speak' so that I have a chance of comprehending it Thanks in advance! Ideally I'd like to get the RAM running as fast as possible.
