Help me with overclock plz.
Zeke
OK< I'm overclocking my P4 3.0C on my Asus P4C800-E Deluxe, it doesn't let me set dividers, so what I ahev to do is set the RAM to run at 320, and then it should overclock as I turn up the FSB, but for some reason, it will always pick up as 320 MHz when I'm booting up after an overclock, how's it possible that it could just be locked like that? When I set it on auto mode, it sets itself to frickin 266, so what do I do? Could i tbe possible that it's overclocking but just not picking up on the RAM speed during boot? Cause when I lock it at DDR400 and then overclock, it wont boot, pressumably because the RAM is being overclocked cause it will boot at said FSB with the RAM speed locked at 320 or lower... Is there any bios revision I can flash that will change this if that's the issue? thanks in advance :D
