- Aug 12, 2004
Ok - heres the deal. My wifes box is a Sony VAIO PCV-RS530G. I've upgraded her box to dual 7200 RPM drives, gig 'o ram, etc. I am now trying to give her my old ATI Radeon 9800 Pro AGP card. When installed about 75% of the time the computer will not fully post - gives random beeps and screen goes nutty. I hooked a 450W power supply hanging out of the side of the case to it and it boots every time - no problem. So I have concluded that the OEM power supply cannot provide enough juice to run all ot this.
My problem is this. The VAIO has a (as far as height and width) standard size ATX power supply but the depth is NON-STANDARD. It is only 4" deep into the case which leaves roughly 2.6" between the supply and the optical drives. Every off the shelf ATX supply I have found is considerably deeper than that. I drew a pic in illustrator to give you all a better idea of my quandry. http://www.sl-digital.com/Vaio-Power.jpg
I have measured and without the optical drives a standard ATX supply does mount just fine but leaves me less than enough room to actually connect cables to or actually install the optical drives. So I have 2 options - find a shorter (depth) power supply or install any ATX supply and additionally find, buy, and install 2 shorter depth optical drives (dual 16X DVDRW drives). I would prefer to find just a power supply as the optical drives are in great condition. I have determined that the max depth of the power supply could be 5.25" which would leave me under an inch to connect cables to the optical drives.
I'd like to get at least 400W into the case. It currently has an NMB 290W supply. Any ideas? Thanks all.
Rich
Rich
