help me deciding please!
Status
Not open for further replies.
jimgeagea
i am currently building a new pc,!
i have DFI lan party Ultra-D
what i need:
X2 dual core, vga, 2gb rams, a minimum of 500gb disk space...
for the cpu i am into 3 choices: 4400-4600-4800
for the vga: do i get the 7800gtx or wait for the new ATI?
for the rams: what are the fastest rams to get?
for the hdd: what is the fastest to get?? i can get 2*t7k250 or 1*7k500
i dont want to get any hdd other than SATA/SATA 2 7200RPM
there is no money problem, so please for each give me your advice, and the full brand, model name..
thanks
By the choices you're giving us, I'd say you're not a budget. Go with a X2 4400+, 7800GTX (who knows when the R520 will come out?), PC3200 of Crucial Value or Ballistix RAM, and one 500GB HD is fine unless you're running in RAID0, otherwise 2x250 is faster.
Status
