Help me decide.
quadnad said:
The x850 will give you far better performance. Compare specs of cards here.
second that...
the X1600 shouldn't even have 512mb of ram, it just doesn't help the performance.
3rd here for the X850. The only benefit you have with the X1600 is the latest in shaders and Avivo.
Looking at ATi's site, they list the X800XL for the same price as the X850 Pro. What exactly makes the X800XL different than a X800 Pro/XT?
Use the link I posted to compare specs. It'll give you an idea of which is superior.
They should be about same performance...
XL might be a tad faster... like 1 fps...
