Help me decide on a case
jhodach
Ok I am confused and lost when coming to what I want or should be looking for in a case. Ill just give some of the components of my future build and what price range/asthetics I'm looking for so that some of you guru's can narrow down my search.
Price-50-180
Asthetics-Prefer Black, and side window
Size-this one not sure. Currently my case size is 16.5"tall by 19.5 wide. I would say I could use a little bigger if it helps w/ cooling
Basically what I'm looking for in a case (besides what I just mentioned) is decent cooling and very little noise. I plan on putting in an Icore 7 860 and overclocking to 3.0ghz at most. I plan on a Corsair 750w PS, a OCZ SSD, a DVD-RW, 4gb of ram, and an EVGA 285 gtx. It's a relatively basic system.
So I'm hoping you guys and gals can come up with some good suggestions for me. I'll check this thread if you need anymore info from me to help narrow down the search.
silverstone ft01b-w if you are willing to go a little over 180.
aluminum, quiet, good air flow, windowed, powdercoated black inside.
