I am putting my 7800GTX card in a HTPC i built, so I need a new videocard for my desktop.
The choice is between the two following cards. Help me decide:
GeForce 7950GX2
Its the fastest card on the market, and I imagine that with a FPS monster like this I should be able to play the most demanding games for well over a year with decent settings.
I have heard of a few caveats though. The first is compatibility issues. My motherboard (Asus A8N SLI Premium) is on nVidias compatibility list, so I am not to worried. However I hate spending days trying to figure out compatibility issues. The second problem that bothers me is that I've heard that with any multi-GPU setup, there are issues when using multiple monitors. More specifically, multi-GPU has to be switched off in order to use multimonitors properly. I constantly use two monitors except when I play games. Can anyone tell me more about this issue? How do I disable multi-GPU? Is it a hassle?
Any other significant caveats I should know about?
Just an FYI, I watercool my videocard. I'm going to cool this card with this block: Danger Den - DD-GX2
Radeon X1950XTX
It's the fastest single GPU card on the market, and image quality supposedly surpasses nVidia's cards in certain games. It's also about $80 cheaper than the GX2.
It's a brand new card, so I'm a little worried there will be issues with drivers and some compatibility during its first months. However the X1xxx platform is tested and approved, so it might not be a big issues. Any thoughts on this? Other than that, the GX2 is superior at high resolutions in all games I've seen. So I'm thinking the GX2 will last me longer.
I'll cool this card with this block: Danger Den Tyee
I'm kinda leaning towards the GX2, but only if someone convinces me the compatibility issues aren't that big of a deal, and that using multiple monitors with this card is fine.
All input gladly appreciated (including info on overclocking and cooling as well)!
Thanks!
GeForce 7950GX2
Radeon X1950XTX
Thanks!
