Hi, there. I'm having laptop woes right now..I plan on getting one around Christmas when I get money, and these are my choices(hoping Dell doesn't stop selling either of these models by then);
$557 Inspiron 1200(http://img.dell.com/images/us/segments/dhs/prodviews/4x_1200.jpg) with:
- Extra battery
- One external wireless (for Type II PC slot - Dell Wireless 1350 External Wireless [802.11 b/g, 54Mbps])
- 768 ram[256 shared, I'm adding 512--ALREADY INCLUDED IN $557]
$644 Inspiron 6000(http://img.dell.com/images/global/configurator/chassis/inspn_6000_cfg.jpg) with
- Internal wifi(Dell® Wireless 1470 Internal Wireless [802.11a/b/g, 54Mbps] )
- 512 ram(shared)
- Integrated Intel® Graphics Media Accelerator 900
Does anyone know if I'll see a reasonable difference in distance and strength in either of these two wifi devices? I'm hard pressed on cash, BUT if the internal has a better signal strength/performance I will consider getting the Inspiron 6000. I probably won't care about a two inch card jutting out of my laptop if it has better signal strength..but will I need that extra wireless-A connectivity that the internal provides?
Also, both entry level laptops have the same CPU speed. Which seems to be the better buy overall? The extra battery with the 1200[free] is $80 retail, BTW.
- Extra battery
- 512 ram(shared)
