i want to mod my case with cool cables that light up.
few questions though.
- is it bad to have cables that light up in anyway? does it affect performance?
- do the lights stay on when the comps off?
- how long do most the lights live for?
- which colors go best with blue leds?
evga 680i mothboard
SeaSonic S12-600 ATX12V / EPS12V 600W Power Supply
cd drive http://www.newegg.com/Product/Product.asp?Item=N82E16827152076
hardrive http://www.newegg.com/Product/Product.asp?Item=N82E16822148144
my case http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
i may also buy 2 80mm led fans to replace the 2 80mms i have, which would u recommend?
i may also be intrested in on of those long sticks that light up w/e they r called.
evga 680i mothboard
