friend'scatdied
- Feb 20, 2005
Ok, this is my current setup:
MSI K8N Neo4 Platinum/SLI
512MB x 2 Dual Channel Corsair Value Memory
160GB SATA 7200RPM Seagate "Barracuda" HDD
Chaintech 6600GT (500/1000)
AMD Athlon64 3000+ Socket 939 Winchester
Windows XP Pro w/ SP1a/SP2 installed and fully patched.
Okay, this is my first personal build ever, and Windows XP is giving me some issues.
The first time I formatted and installed Windows, everything ran fine and drivers installed smoothly. I started by installing the Forceware 70.78 Quadro drivers as someone suggested to me and ran the games I could run in OpenGL. They ran OK.
However, then I tried the Painkiller full game that came with my 6600GT. It ran incredibly smooth and framerates soared. However, after I try to exit the game, without any notification from Windows whatsoever, the screen goes blue for a split second as the entire system crashes and auto-reboots.
Being quite worried, I tried uninstalling various drivers with no luck. Since I had disabled System Restore, I was hasty to reformat (although probably not the best option).
This time, I chose the quick NTFS setup and started it up. This time, I installed the drivers one by one. Games still ran fine at either D3D or OpenGL at this point, and didn't crash. I installed the drivers that came on the disk for my 6600GT. Again, fine. Then, as I installed Razer Diamondback drivers that came with my Diamondback, things started crapping out on me. I uninstall the Razer drivers and to my horror the crashes are still there post-game.
I system restore back to the previous pre-Razer state. Phew, the problem seems to be fixed now. However, soon I chance it and try the drivers again and the problem arises again. Then, I uninstalled and system restored back. This time, I wasn't so lucky as the crashes still continue. As I got the same post-game crashes, I did Norton and PC-Cillin checks and successfully removed one worm and two backdoors (the names of which I forget). The crashes still continue. After each crash I check the BIOS for CPU temp just in case. They turn up at about 40'C max, and my setup got at a peak of 43'C after 1 hour of the Prime95 torture test (I use a Zalman CNPS 7000B AlCu with Arctic Silver 5 so these temperature are underwhelming for the circumstances).
I highly doubt these are hardware problems and I really think these are moreso OS problems considering in the actual games performance is sky-high and just as it should be according to benches. It is only when I try to exit back to my desktop that crashes occur. Except for games, everything runs stably and smoothly (Firefox, AIM, Winamp, etc.). Spyware is probably not an issue as updated Spybot/Ad-Aware checks yield nothing. However, I threw down $800 for this setup to play games smoothly and I don't want to risk long term damage or stability issues with these crashes.
Anyone know some answers? I came here because I heard this was a great place for diagnosing hardware problems.. Thanks in advance.
