Hello,
I recently bought a Sapphire X800 XT off eBay. It is the blue card with alien sticker on the fan. However, the card would not work stable at stock speeds.
I'm suspecting that I got nothing more than a soft-modded/flashed Sapphire X800Pro(which as you know comes with VIVO, 1.6ns Samsung DDR3). The card looks the same, the bundle looks the same(apart from "disappeared" box and manual).
But that's not all. The product sticker on the back of the card is missing. You probably know what this means. I cannot identify the card or RMA it.
I was wondering if there was a way for me to find out whether what I have is Pro or indeed XT. I wouldn't want to stir a trouble with the seller before I'm positive.
Thanks much.
Thanks much.
