help identify case?
spartigis
this is a picture of a xerox printer controller- or something, at a place I worked back in 2009. i really liked this case but could never find the manufacturer name or a model number. this case has "external" filters for easy cleaning. anyone ever seen this case or something similar before?
I am guessing that Xerox designed and manufactured it. I am also guessing that you have about 0 chance of acquiring one unless you happen to come about one at a surplus store or if you contact Xerox directly. Even then they will likely just sell you the entire system and not the case and is likely next to impossible to order the case by itself. My advise, either build a case from the ground up or look somewhere else for a case as this is likely a lost cause. Not trying to put you down, just being realistic.
understood, thank you for your response. I liked the external filters, any suggestions?
