Help: HP + USB KB + USB Mouse = Not Working
BinarySynapse
Okay so I'm borrowing this wonderful (hey it's better than the iMac I was using) HP Pavilion 520c from a friend. All I have is my USB keyboard and USB mouse. When I plug them both in together I can't use the keyboard until after XP has booted. If I unplug the mouse and reboot the keyboard works fine. What is causing this?
Most likely it is a setting in the BIOS. Play around with the different settings on the USB Legacy Device support. I believe default is enabled, try setting it to disabled. Seen some wierd stuff with this setting on a few premade systems from various manufacturers.
lol by wonderful i hope youre sarcastic...
But as the previous poster mentioned, it is likely a bios setting. I have had more keyboard mouse issues with computers, you dont even know.
If you happen to have a spare USB -~- PS/2 converter layin around, i would suggest trying that with the mouse. ( or maybe a dumb suggestion but check that the ports are all functioning )
