help for a configuration
Newbiejob
Hello,
I am a new and I have to desktop configuration to create. Here is the first one. It's for an architect. Could you tell me where are my mistakes ?
Thank you very much for your help.
N
looks fine but you dont need to buy a sata cable, the motherboard will come with at least 2 and you only have 1 sata drive.
Hello,
I forgot to choose the computer power supply. I can't find how to choose it. I know I must consider the cpu and the GPU. But I still don't find how to choose it.
Anyone can help me ? Thanks.
Hello,
get a decently rated unit that is the minimum recommended wattage for the gpu. if you ever plan on overclocking it, add a couple hundred watts.
