STrooperTK421
- Oct 8, 2009
My wife's computer (desktop) is in need of a wireless adapter. I already tried one, a USB Netgear job that I bought for about $35 dollars, which turned out to be a complete piece of shit. It would work fine for a while, then it would just cycle through the channels over and over again and even when I manually pointed it at my wireless access point it did nothing. I would have to completely uninstall the device and software then re-install everything, that just sucked. Then even that stopped working and out of hatred and spite I put it in the microwave.
I have searched the egg, but everything that I see seems to be "somewhat" crappy. Frankly I don't care if its PCIe, USB 2.0, it just doesn't matter I just need something that doesn't cost a fortune and that actually freaking works.
Also, why does it seem that PC's with built in NIC's have the NIC portion go tits up after a year or so? I have had 4..yes 4... separate computers that the NIC just "stops working" and will no longer see the network or anything, but Win swears up and down it is working properly...
I really really HATE that.
