Help diagnosing issue with BSOD?
Apex
Ok, I'm having problems with my tower. Sometimes when I'm doing one of two things, the computer with BSOD. That is:
1.) When I'm encoding video (mostly when I'm converting to a DVD standard from AVI), either with Adobe Premier Pro CS4, ConvertXtoDVD, or Nero. SOMETIMES, about 10 minutes in, it'll BSOD and reboot.
2.) When I'm switching channels from SD to HD with my tv tuner
Setup is seen in my sig and this is while running Vista 64 bit. I looked at the FAQ and have already tried all that, bios is up to date, all drivers for all hardware is up to date.
The memory is Kingston DDR21066 (clocked at 800mhz, recommended timings), I'm running my Q6600 @ 3.0 GHz with a Arctic 7 Pro that keeps the temps below 45 while encoding or under full load, but I'm beginning to think I may know the source of my problems.
I'm running all this and an Antec 1200 with its 2,000 fans off of an Antec Earthwatts 500 watt power supply. Is this the source of my problems? I can run Crysis and any other game where the processor also gets nearly maxed out for long periods of time, and so does the vid card, I never have a problem then. It also is fine when it spends about 5 minutes converting ~500 21mp RAW photos from my 5d Mark II with all 4 cores maxed out.
So, could it be the ps? Is there any other details I should provide? I really appreciate your input(s). I need to get this figured out, I have a DVD I need to put together for a family friend.
I don't think it is your PSU since other intensive work (such as Crysis) runs well.
Did the software work well before, only to start failing after a change of software or hardware?
Restore you BIOS to stock settings. Boot up, try to encode something. If it doesn't happen, we both know what the problem was.
