Help!! Computer Won't Boot
The problem with that is there are no good OCing mATX s939 mobos. Otherwise I WOULD have bought that case and a modular PSU.
I don't get it. Doesn't the same problem as easily apply to shuttle as anyone else?
No this baby OCs like a champ, 300fsb is no problem.
The other ones would be lucky if they could reach 250.
And that particular board is ONLY sold in a pre-built shuttle system? Don't they also sell boards seperately?
Well, anyway, whatever. If you don't mind giving them your money for a better OC, I guess that's your money to do with as you please.
Good luck on getting it RMAed and all. BTW, you may need to check your other cards as well if you haven't already. If it caused a surge or something, it could have caused damage to other components. I once accidentally touched a universal adaptor (which means in the area of 300mA, 500 tops) from a speaker -- probably 5V -- against a case and it ruined most of the components in that system. Mind you, that was an old system and they may be better designed today (I think it was my 286...)
