I've got major problems here, 1st off here is my setup
AMD Athlon XP 2500
Shuttle AN35Ultra
ATI 9600
1 gb ddr 2700
big typhoon cpu cooler
It was running very slow for some odd reason, so then I went to restart it. It restarted and frooze on the bios start up screen. I shut it down, reset the BIOS, then I went to restart once again. This time around I got nothing no signal to the Monitor. And the computer does not start boot sequence. (meaning) No beep. But does power Up, all my fans and lights turn on and also the small light on the motherboard turns on. I've swapped out my memory and nothing...I willing to guess my CPU is fried.
Does anyone have any Ideas?
AMD Athlon XP 2500
Shuttle AN35Ultra
ATI 9600
1 gb ddr 2700
