HELP!!!!!!!!! Catalyst 12.2 wont open!!!
HELP! Catalyst wont open.
Hi, I am currently using ATI 6970 and every time I reinstall Catalyst, it works briefly, but once I restart my system, it fails to work again.
I have tried uninstalling and reinstalling, I have tried using Driver Cleaner from safe mode, updating my .NET framework, I have reinstalled my entire windows 7 OS, to which all of them have failed.
Catalyst does open, but only the advertisement loads, everything else does not load.
The weird thing is sometimes, catalyst would work for certain periods of time, and then all of a sudden it would go back to not loading.
heres what it looks like
http://i1269.photobucket.com/albums/...6/Catalyst.png
http://i1269.photobucket.com/albums/.../catalyst2.jpg
As you can see, it basically "half loads" none of the options in the sidebar loads, i can even move it around, but it just wont fully load.
Please help me solve this problem!
Thanks for your time!
I have the same problems, except it disappears randomly and will not come back until I sweep the driver. This is why I will be going green when they are released.
