so i was sitting at my computer last night chatting away, and all of a sudden it restarts. i don't think much of it and let it boot back up..problem is it gets to the windows loading screen, you know, the one that says Windows XP Pro and the little bar under it going from left to right, it gets past that and acts like it is about to give me the screen where i enter my password to log into windows, but it just goes to a black screen and restarts again.
it does the same thing in safe mode, debugging mode, and every other mode. it gets past the loading part and is about to give me my password prompt and just restarts.
i figured i needed to check the system reboot on system failure or whatever it is and make sure it was on, but i can't even get to windows to do that.
when i loaded up another harddrive, it went fine, and i also loaded up my harddrive as a slave on the other harddrive and i was able to get to my files.
so i figure i have some kind of virus or something that changed my boot settings to restart, has anyone else had this problem? what do i do?
please and thanks.
EDIT: System specs in sig.
please and thanks.
