Help! A8N32-SLI problem, new build, will not boot.
aaronpeek
Just bought a a8n32-sli board, with a 4400+, 7900gt, corsair ram, and a lian li pc-777 case.
Ready to rock? Right? No
I boot up and the fans all turn on, no picture on the screen, no beeps....nothing.
Is there something special i have to do with the graphics card? i mean there is gotta be something small i am missing.
Also the Cpu_fan slot will not run the fan on the athlon 64 proc. i have to plug that into the chassis fan 1.
I am not new to building systems, i am so perplexed right now.
if the cpu fan isnt running on the cpu header but on others there could be a mobo issue..are all of the power connections connected? the 4 pin? also the system might not boot because of no fan speed detected on the cpu header
Unplug your periphials one at a time and try it, you may have something drawing to much current.
Would it be green and have the word 7900 all over it? :)
You never said what PSU your using ?
Your HD , is it formated or do you have an OS on it ?
Are you using the easyplug connection for your graphics card ?
Have you tryed booting up without your card in and using the OB graphics ?
As you said your not new to building so i would imagin you have made sure all the connections are secure and tight , But some times it helps just to make sure
bum board, new one installed, works great. Where can i change the memory timings in the bios, it is greyed out.
Im not on my PC at the moment so this might be a bit wrong .... i will post later with the right way but untill then... from memory here we go .
Bios ..
jumper free config
Ether ecc config ( or the other one) set to manual .....This then reveals the timing settings try both .
I know thats not much help ... but its the best i can offer untill im at my workstation..sorry
how do i find the right timings to put in it 2.0-3-2-2 but what is what?
TWINX1024-3200C2PT is what i am using
still cant figure out which goes to what number 2-3-3-6, does the first 3 go to tras or trcd, Is there a universal sequence?
I have diffrent RAM to you ( G Skill HZ) but i changed mine to (from top to bottom in the BIOS) 3-8-4-4. Cas set to 3, tras set to 8, trcd set to 4, and trp set to 4. I also had to change my ram to 2.8v.
You do the same with your 2-3-3-6 ...mAKE A NOTE OF THE DEFAULT TIMING JUST INCASE IT DONT WORK THOGH ;)
I have this board too, and even when using 1 graphics card, we still have to plug in the EZPlug as well into the motherboard?
eVGA 7800 GT, ASUS A8N32-SLi, amd x2 4800
This sounds familiar. My first A8N32 - SLI board would not boot at all, even with the minimum components to get it to post. I RMA'd it and the new one has been flawless.
No.
Done, all set to best timings, works flawlessly. Picked up 1500 points in 3dmark03
wow, 2.8v vdimm?
uccc ram does not like high voltage. have u tried running it at 2.6v?
im running my HZ set right now at 2.6v 255fsb 1:1
As soon as I saw it was an Asus, I was about to write and say try another board. But as I scrolled down I saw this. Glad you solved it. I have a love/hate relationship with Asus, as I too have received bum boards right out of the box. Still a nice board though! Congrats on your new rig!
