Help! A7N8X Deluxe?
bikeboy24
Does anyone hae a A7N8X Deluxe?
I just bought a motherboard used, but it seems like the seller screwed it up when trying to flash it. Now it won't boot up, and it gives me a bios checksum error. When I try to reload the bios, with the built in recovery, AWDFLASH says source file not found.
Apprently, I need the AWDFLASH that came on the CD that came with the motherboard. I never got this though. Could someone please send me their AWDFLASH.exe for the A7N8X Deluxe? Thanks in advance.
Which version of the board do you have? 1.0x has different BIOS than 2.x boards. It would say on the board between the PCI slots which version you have. That may be your problem.
Would the AWDFLASH be the same though? Or would be looking for a specific bin file? Could I try it anyways? If possible, please send AWDFLASH.exe to
kwong24@rogers.com.
THANKS!! :)
