dannyallen34
- Jun 9, 2005
Hey, I was wanting to do dual monitors with a 2405FPW and a Dell 19" LCD but my computer (a Dell) is a low-profile computer so it needs low-profile AGP cards. My PCI slot is filled so I need a good dual monitor video card with a VGA and a DVI slot that I can use in my low-profile computer.
I know that you can't fit two of those ports into the braket of a low-profile card but I planned on having the VGA run out of the case of my computer either through the edge of the back or through the AGP slot by maybe taking the braket off since it wouldn't fit anywhere else. Here is the card I was looking at:
http://www.newegg.com/Product/Product.asp?Item=N82E16814121542
Is this a good card for what I plan to do? Would it run one 1920x1200 monitor with DVI and run one 1280x1024 monitor with VGA?
