Boardin087
- Jul 2, 2003
I recently bought a front bay fan controller/temp monitor. it said to hook the temp monitor up to the HS. I wasn't sure if they were the same or higher temps then the cpu. anyone have ideas?
It would depend on where you put it since I doubt it's uniform, but I would still say it would be less. Even copper is not 100% efficient at extraction and retention. I'm not sure of the exact differences but I would imagine your results will come up a little optimistic.Boardin087 said:I recently bought a front bay fan controller/temp monitor. it said to hook the temp monitor up to the HS. I wasn't sure if they were the same or higher temps then the cpu. anyone have ideas?
