I think my PC may be getting a tad hot, the cpu under load reaches 110c and i can feel the side of the case is really really hot, I've not overclocked and have never done so
Oh and there IS actually 16GB of ram in there as speccy says, windows only sees 8GB max
edit: if i try to render, or play Call of Duty the PC is ok for about half an hour then it shits itself and turns off
