Heater Core question
I have a little wonder in my head. I went to a part store today, the ones that have just about every used part you can think of and I saw a bunch of heater cores avil. They were pretty big, and I was wondering if they would fit in a cheiftec case ( the10 bay version with the window) I was going to take a drive cage out, take out my floppy and use a zip drive for the mean time. Take out a tv card,xtra usb, and this 28k modem that only worked twice. The heater core was from a plymuth i think and it was very nice. A little scrubbing and it would go fine. I would convert the tubes to 1/2 inch by the way. Any help would be nice, thanks.
measure it... then c if it fits.
But heatercores rule with a 120 mm fan. Best cooer in da world.
I just ordered a 77 bonneville core .... 2 120mm fit perfect on the 10 3/4" one. $17.99 =)
Yea the one I saw is like pretty nice I think it will fit, me and my dad can come up with something to make it work. Other than that My theming will be "UV" Fans,cathode,round cables, and the core is going to be sanded and painted UV along with dye in the water. Gimmie like a month or so and Ill be ready :)
