i have this case http://www.newegg.com/Product/Product.aspx?Item=N82E16811119150 and just found out it wont fit a cool master v8 cause the 200mm fan on the side of the case and i was trying to see if this one was smaller http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003 and here the bracket http://www.newegg.com/Product/Product.aspx?Item=N82E16835233027 and do you think it will fit on the mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
