Heat problems with A7N8X-E Deluxe
jdarrish
Lian-Li PC-60
Swiftech MCX-462+
Arctic Silver 5
Enermax 431 PSU
Enermax 80mm fan (turned up all the way, about 30-40 CF/M)
I recently switched from an old MSI KT3-Ultra-ARU to an Asus A7N8X-E Deluxe. Everything hardware-wise stayed the same, except I removed an old 3com NIC (in favor of the on-board).
On the MSI board my t-bred A 2200+ would idle around 44*C (around 41 with the CPU HALT detection enabled in the MSI bios). It would hit about 55*C when I was too lazy to turn up my fans during a game of CS:S. It never became unstable.
When I switched to the Asus, my idle temp rse to about 55*C, and hits 58-59 when I'm playing a game. I suspected I screwed up the thermal grease, so I reapplied and reinstalled the heatsink. Same thing, even after a couple days to break in.
My VCore is set to 1.65, but the bios reads back 1.70, as does MBM. The nVidia utility reads 1.65.
What's the deal with this high temperatures???
Thanks,
Jeff
Just for clarity's-sake:
The CPU is not overclocked (god, it'd melt). My FSB is set to 133x2.
I've installed the heatsink both times the same way I always do. This is probably the 8th time i've reinstalled it, so I don't think I'm doing anything wrong with the Arctic Silver.
I was worried about build-up, this being one of several installations on the same heatsink and chip. However, the heatsink was reinstalled at least 6 times on the MSI setup with no signs of any increase in heat due to residue or build-up.
