I ran the computer on my sig without the 6600gt, 1 less HD, and a stock P4 heatstink.At that time my soyo hardware monitor reported my CHA temp at 32C and my CPU temp at 45C. However when I upgraded to my current rig(sig), my soyo hardware monitor is reporting the same exact temperatures. This was a little weird so I ran Speedfan and it's reporting:
Temp 1: 32C Blue
Temp 2: 75C Red<----------
Temp 3: 20C Green
HD 0: 38C Green
HD 1: 35C Blue
HD 2: 39C Blue
Temp 1: 75C Red
Note: Green = good Blue = fair Red = not good
At the moment I'm assuming Temp 2 is my CPU temperature and 75C isn't too good. One question I have is that my heatsink is secured to the mobo but it's alittle pushed or shoved on the sides by the PSU and it's lifting the mobo with it. I'm hoping this isn't a big issue because at least it's secured together. Another question is once I applied the thermal grease on the heatsink and attach it to the CPU, is it bad to detach it and reattach it again to get a better surface area? I noticed that the thermal grease no longer had a evenly smooth surface but had little "dabs" of grease on the heatsink. Basically I need to somehow lower my CPU although the heatsink itself it nowhere warm. In addition my HD is EXTREMLY hot hot hot.
Temp 1: 32C Blue
Temp 3: 20C Green
HD 0: 38C Green
HD 1: 35C Blue
HD 2: 39C Blue
Temp 1: 75C Red
