So I want to hook my pc up to a HDTV, which has hdmi and vga inputs. I tried out the vga input using my brother's vga cable, and it looked really nice. I used a dvi-vga converter, and from there, the vga cable to the hdtv. The only problem is, the cable is short, and I have to move my PC, which I don't want to do. A cable that is 10 feet long should suffice. So pretty much I have to get a new cable. Only thing is, hdmi/dvi cables cost a lot more then vga cables.
So would the dvi-hdmi cable be worth it over the vga cable?
