hi all,
just chasing a bit of advice, I'm building a pc for my dads business that's only going to be used maybe 5 hrs a week. but those few hours I'd really like to keep it running and data loss protection is paramount. so asside from backups after every session I'm setting it.up with raid mirroring, my question is what do you guys use to run New HDD through their paces and prove to the best of your ability they aren't bad from the factory?
on a side note is there anything in addition to my list youd recommend after a new build to prove reliability?
memtestx86 for 24 hrs
prime95 for 24hrs
Intel burn test for a couple of passes
thanks in advance
krita
prime95 for 24hrs
thanks in advance
krita
