Operaghost
- Jun 4, 2004
I just purchased a Westinghouse TX-42F430S. I went to the local Comcast and swapped my DVR cable box for one that had an HDMI output. I got home, hooked it up, and started browsing around different channels to see if it was working properly. I noticed that on some the "HD specified" channels such as ESPNHD and the ABCHD, NBCHD channels that the resolution would shrink and not fill out the screen horizontally. However, the TNTHD and a few others would. So I was thinking that the channels that were shrinking the image were being displayed in 480 or maybe 720, however, when I checked the Info on the output, it read: HDMI: 1080i. So if it is in 1080i, why is the screen horizontally shrunk?
Also, are there any other comcast users that noticed that you have to change to the "HD specified" channel to view programs in HD, even though the normal version of the channel says "HD". Such as: Fox is Channel 5 for me, and on some programs will say "HD", but it still displays in 480 unless I change the channel to 705 which is FOXHD. Is that normal?
