PizzaFiend
- Aug 4, 2005
Hey folks, Ive lurked these boards for a year, but this is my first post.
Im using a local store built comp , about a year and a half old. No problems whatsoever with the computer.
About a month ago, the Western Digital IDE drive started acting up, I could surf, but any game like World of Warcraft the drive would start grinding/clunking/spinning up and down, ect, I have would have freezes/lockups when it was accessing the drive while playing.
I have had other HD's die with similar problems, so I called western digital and x-shipped a replacement. I had a friend do a mirror image of the drive onto the new one, and it worked fine for about a week, now the same thing has started. Sometimes while moving the cursor around on the desktop, it will freeze momemtarily and jerk around the screen. The odds of another defective HD are slim, so which direction do I go now?
Possible problems are power supply going bad/not enough juice?? Im using a no-name generic 300W power supply, and I did upgrade to a BFG6800GTOC AGP about three months ago. I have some lighted case fans, and ive noticed they dim/flicker at times under heavy load.
Only other possibility would be the HD controller is going out on MOBO??
Any troubleshooting suggestions/sources of this problem, I would greatly appreciate your input......
Thanks, Pizzafiend
MSI Neo mobo
AMD 64-3200
1 gig kingston ram
bfg 6800gtoc agp
SB audigy2 zs
Thanks, Pizzafiend
MSI Neo mobo
AMD 64-3200
1 gig kingston ram
bfg 6800gtoc agp
SB audigy2 zs
