Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Cable select will set the drive to master or slave depending on which plug the drive is in. (when using a cable designed for cable select... 99%+ of them)
If the drive is on the last plug, it will be master, if it is on the middle plug it will be slave.
So if you have one drive jumpered to master, and it is on the middle plug, and you have the second drive on cable select and it is on the end plug, they will conflict just the same as if you had them both set to master. (same for slave, if the end drive is slave and the middle drive cable select) If you have the master drive on the end, and the cable select in the middle, it will work. (and again if you have the slave in the middle and the cable select on the end, again it will work)
There is no advantage to using cable select over configuring it yourself.
