Having problems with front panel LCD
Vipex23
I have the Spider 2 case:
http://www.newegg.com/app/ViewProductDesc.asp?description=11-148-009&depa=0
This case comes with a front panel LCD Temp display that currently is not working. I believe I have all the wires plugged into the MoBo correctly. I currently have 4 wires connected into my MoBo's Front Panel Connections part. My Power LED and HDD LED, which are both working fine and my reset and power buttons, which are both working fine. Is there another wire that should be plugged in there?
My MoBo is MSI K8N Neo2 Platinum
If you require any more information, please post a reply. Thank you.
Hi, thanks to the reply. They're not opened on the weekend so I thought I'd post here first and see if anyone has this case and can offer some advice before I'd call on Monday. Unfortunately, their site doesn't have any FAQ's. No paperwork even came with the case when it arrived.
Other than the LCD display, everything else is plugged in and working perfectly. Does my MoBo allow for more than 2 LED's?
My MoBo manual reads:
"The mainboard provides two front panel connectors for electrical connection to the front panel switches and LEDs."
From the pics, there is a 4 pin harddrive/CDROM style power connector coming from the front. I think the front LCD is self contained so it only needs a power connection from the power supply.
