Having hardware issues, maybe
frostyboy
This is my first post here so let me say hello to everyone reading this and looking to maybe help me with my computer issues.
As for me I'm normally a console gamer more then i used to be because its more easy to deal with all my PC experience comes from salvaging systems and this time I picked up a custom built PC from my brother, which he didn't want cause he built a whole new system
Now the build includes a DFI KT400A Inifinty / LANParty KT400A motherboard with a CPU Type AMD Athlon XP, 1917 MHz (11.5 x 167) 2600+ CPU (using Everest for all this) I have swapped the HD, Power Supply, DVD-RW drive and RAM as well as taken out things like his old capture card and anything else that wasn't necessary
So I'm looking a MB or CPU or maybe even a driver issue in this case from what i beleave. I want to learn about using raid systems and custom builds before I sink money into my own build.
The only problem my brother knew about was the shot HD whch i had replaced cince I picked it up a few days ago.
-THE PROBLEM(S)-
My main issue is when I am running windows and begin using up resources the PC shuts off (Drives and PSI slots) from what i can tell (no power to those areas) but all LED lights and fans still run no blue screens, also I have to shut it down manualy after this happans.
Once it reboots it apears information is still saved because firefox will still leave off at whatever site I left off at, I was thinking it could be a configuration issue so I already cleared the CMOS and reset the bios, with this MB and what I know about it I am running the pre-configured setup (one was fail-safe the other is what I have the settings on right now I beleave its performance but not sure)
One other issue I have is the sound, everything suggests Realtek AC'97 audio drivers for my "Audio Adapter C-Media CMI9739(A) @ VIA AC'97 Enhanced Audio Controller" (copy and paisted from Everest) but with the realtek I get an error code 10, no responce from any audio settings. If I go with the VIA AC'97 WDM driver it does apear to function right but I get no sound what-so-ever wich leads me to think do I have a bad ground wire on the motherboard?
I know this is a complicated issue and I'm not working with much but this is more of a trial and error kind of deal for me untill I know what I'm working with so I don't run into as many bumps when I do put money down for a stable system
if you're running windows 7 then it's possible it's not playing nice with your, frankly quite old hardware.
is DFI still around? if they are (still around) they probably won't have updated drivers for windows.
if windows is crashing without error, you''ll need to enable blue screens to get a error msg.
http://pcsupport.about.com/od/windows7/ht/automatic-restart-windows-7.htm
you could try dl'ing ubuntu and either installing it to HD or booting it from a CD/USB flash drive to see if it has similar issues.
