Okay well, i have a new sound card and decided to format my sata drive and reinstall windows... My dilema is this, i have windows xp 64bit I like it but i was also able to get windows vista except i am not sure if it is 32 bit or 64 bit since i got it from a friend and i no longer speak to him.
My first question is since i have xp 64 on the machine now, when i go to install vista it comes to a screen where i can pick basic, home, premium, ultimate. would this mean that this is the 64 bit vista version ? i doubt that if i have xp 64bit that the vista would upgrade or install a 32 bit version of vista right?
Second question, i have two sata drives on my pc first drive has xp 64 bit and the second drive is just holding the windows vista files nothing installed. what i do is i start the windows vista install from the second drive to put it on the first drive. but since the second drive does not have a os on it does it know that i have xp 64 bit on it the first drive or does it think its a fresh install and is putting vista 32 bit... cause i have tried this but i do not know how to tell if i have vista 64 bit or 32 bit running and help ??? thanks
