Have timeless returned?
I seem to recall seeing these at least, can't place if I've read anything on it thou.
No, TTs have not returned. Server .133 shows 1 available WU for download on the Server Status page. Sorry. Not sure why they are showing up on the Project Summary page.
Well I'm crunching on three 772's and a 773 and unitinfo.txt does not show a due date. And they were downlaoded in the last two days.
TTs = Timeless Tinkers, the one and only Deadlineless work unit type sent out to those requesting Deadlineless WUs on older hardware.
77x have no final deadlines, but are not considered Deadlineless work units in the traditional sense because they are Gromacs work units. Older hardware doesn't have SSE optimizations to make TGs a suitable replacement for TTs, as TGs would fold much too slowly (1/3rd the speed of TTs).
Timeless WU's weren't always tinkers, were they?
Yeah, I also seem to remember that there used to be non-tinker timeless WUs.
I dunno, technically you might be right BUT... Run anything on a AMD K6-2 300 (I have) and it's gonna take a long time no matter what you have cooking. SSE or no SSE GROMAC or Tinker you hosed either way.
marty9876 said:
I dunno, technically you might be right BUT... Run anything on a AMD K6-2 300 (I have) and get you hosed by zim01.
and the "I have sinned" page gets closer to returning :p
Okay, you got me. Never say "never" as it's a very long time.*
Yes, a very small number of TGs were released as an experiment quite some time ago. (Damn, you have a good memory.) But the result was as I said. Instead of earning 5 PPD, machines without SSE were only earning 1.67 PPD. And because they folded so slowly, they were guaranteed to miss the prefered deadline, which guaranteed the WU would be assinged to a second person, which guaranteed the duplication of work units and very long delays in the return of the work units. The automatic duplication of work units, and extremely long return times go against the goals of the project, even for "Timeless" work units. As such, TGs were pulled from the Timeless WU Assignment Servers shortly after their debut, never* to be sent out as TGs again. (only as Gs with no Ts. ;))
I figured this was is response to people yaking about clients not getting any work due to being set to timeless. There is a thread over at the offical forums, I forget where it left off at. Last I read VJ was thinking about release something to the timeless masses.
Config a client for timeless and see if grabs one. If grabs one, good enough for me to call it timeless!
Well my X2 3800 just grabbed two more 772's and emIII is reporting 109 and 101 ppd while surfin. email, some games and here. These have a please return by of 300 days!
I've got type 3 and nonet set, but it only picks up one WU (not 10) at a time.
But then my Linux box picks up a 1496 with a "please return by" of 48 days.
Fold ON!
I had several old clunkers in my farm doing Timeless WUs. They had been set to download a batch of WUs, then work on them one by one, returning the results as each one completed. Even after the Timeless WUs disappeared from the Stanford servers, they kept on folding and returning WUs.
Recently EMIII showed that these machines were folding away, but the WUs were not being returned...they were being completed, queued up, but not returning. :( The fahLog file showed repeated attempts to return the WUs, but no success. So, I deleted everything except the console, restarted, and skipped the Timeless option. They are now folding away happily, and hopefully will not just be heating the area but returning WUs. I'll check on whether they are meeting the deadlines, and if not, I will retire the boxen from folding service.
marty9876 said:
why set an x2 3800 to timeless?
I had some issues with a crashing system, and I go on frequent travel of 2 weeks or more. Then after I got the system semi-stable I forgot I had them set to timeless
:rolleyes:
Another note - I ran the instance that had a 772 with -oneunit, then reconfigured to get regular (not timeless) WU, deleted work and que.dat, and it still continued to pick up 772's. So I built another instance with an ID of 4 and I finally picked up a regular WU.
