The book I ordered says it will require 2 installs of windows 8, and 1 of server 2012, all running at once to learn Group Policy and Active Directory. The book recommends running VMware Workstation for virtualization, but makes no mention of the amount of ram required to do this. How much is enough? Would 8gb work? Also, would a Core i5 2.4ghz work? I am looking at setting this up on a laptop I ordered for $200 on ebay, and the ram would cost $60 to upgrade it. The reason I want to do it on a laptop is that then I could take it with me and work on learning Group Policy elsewhere, besides at home.
The laptop has a 160gb hard drive, which may be too small for this. Would I need a hard drive, if this system is even able to run 3 virtual installs? It has Windows 7 installed, as the OS that I would use for the virtualization software. The purpose of the installs is 1 for management of the server, 1 for the server, and 1 as the client.
VMware Workstation costs $187. He says you could also use something else to run the virtualization, like Hyper-V on windows 8. What effect on the setup does the virtualization software have? Are some more efficient? Why buy it?
I'm just wondering if it can be done on this laptop, with it's maximum ram of 8gb. And what else do you think I would need to do it?
